Author Topic: 70 seat side Hinge Bracket, left  (Read 1131 times)
Offline silverelvis69
« on: September 02, 2023, 08:31:18 PM »
Hi All,
Can anyone guide me or is there any video on replacing this drivers seat hinge>
D7ZZ-69618C46A
Many Thanks
San Jose built
11/69
Dark ivy green metallic
Ps A/c
Re: 70 seat side Hinge Bracket, left
« Reply #1 on: September 02, 2023, 10:52:33 PM »
So your doing this on a 70?  Guess it will work but originally the recall and part were made to address the 1968 and 1969 Ford and Mercury models but guess it could be adapted to later seats and frames. At least from what I've collected over the years. Since this was a 1977 recall/campaign for a 9 year old car I don't think I've got TSB's from 1977 that would cover this application. Believe that is where your going to need to look to
Here is the other thread on the same topic but titled for 68 since that was the first year of the recall and fix. Found using the words "seat recall" in the search engine. May merge these two threads together
https://www.concoursmustang.com/forum/index.php?topic=20631.msg130301#msg130301
For others - what the kits looked like and the recall/campaign (as Ford like to refer to these things during the era) some information related to that
Just a couple of the 4-6 listings I found when I last checked
Recall Date: MAR 28, 1977
Model Affected: 1968 Ford Mustang
Summary: THE SEAT BACK PIVOT PIN BRACKET ON THE INVOLVED VEHICLES MAY FAIL. CONSEQUENTLY, THE SEAT BACK WILL ROTATE REARWARD.
Consequence:
Remedy: THE DEALER WILL REPLACE THE DRIVER"S SEAT PIVOT PIN BRACKET ON ALL AFFECTED VEHICLES, FREE OF CHARGE.
Potential Units Affected: 480000
Notes: FORD MOTOR COMPANY
Recall data for: 1968 MERCURY COUGAR
NHTSA Campaign Number: 77V043000
Manufacturer Campaign Number:
Make: MERCURY Model: COUGAR Year: 1968
Component:
SEATS:FRONT ASSEMBLY:RECLINER Manufacturers Involved: FORD MOTOR COMPANY
Begin Date Of Manufacturing: End Date Of Manufacturing:
Recall Type: V
Potential Number Of Units Affected: 480000 Date Owner Notified By Manufacturer: 19770502
Recall Initiator: ODI
Manufacturer Responsible For Recall: FORD MOTOR COMPANY Date Report Received By ODI: 19770328
Date Added To File: 19791012
?THE SEAT BACK PIVOT PIN BRACKET ON THE INVOLVED VEHICLES MAY FAIL. CONSEQUENTLY, THE SEAT BACK WILL ROTATE REARWARD.?
« Last Edit: September 02, 2023, 10:58:31 PM by J_Speegle »
« Reply #2 on: September 03, 2023, 03:10:18 AM »
My Car is a 70. yes
This part was inherited when I purchased the car.
Look its not that bad - on a slight tilt. So do you think this can be done for a 70.
Just no video on how to? that I can find?
San Jose built
11/69
Ps A/c
« Reply #3 on: September 03, 2023, 10:50:54 PM »
Found this for anyone to help down the track
« Last Edit: September 03, 2023, 11:13:10 PM by silverelvis69 »
San Jose built
11/69
Ps A/c
« Reply #4 on: September 03, 2023, 11:40:45 PM »
Guy kind of skips the "repair" part of the process from what I saw in the video
« Reply #5 on: September 04, 2023, 02:19:13 AM »
it shows how to  replaced the whole seat base however ...it does guide you what do look for..
I guess you have to grind out exisiting weld and place this bracket over and drill a hole to bolt it onto the frame
I  also  found this on the cougars pages however - seems to be missing part of step by step photos sadly  :(
https://www.motortrend.com/how-to/127-0311-ford-seatback-fix/
https://forum.classiccougarcommunity.com/t/1968-cougar-left-bucket-seat-hinge/11549/21
« Last Edit: September 04, 2023, 03:16:24 AM by silverelvis69 »
San Jose built
11/69
Ps A/c
« Reply #6 on: September 04, 2023, 05:37:29 AM »
The drawing looks like one typically with a TSB.
Yes you to clamp and drill a hole for the bracket and hopefully don't have any damage to the frame or cause more when removing the original pin. Would be great to find the text that goes with the drawing since that normally includes the steps needed for the process
Offline Anghelrestorations
    • Anghel Restorations
« Reply #7 on: September 07, 2023, 02:12:45 AM »
I have most if not all the TSB's.  Do we know when we think that TSB was done?  1968?
Marcus Anghel
www.anghelrestorations.com
« Reply #8 on: September 07, 2023, 03:39:52 AM »
Guess your referring to having the ones that cover the classic Mustang years not the 40's, 50's or from the 80s plus. Can't recall if all were labled as TSB but like the 60's there were also Service Bulletins and at least a couple of other forms of communications to the dealerships that were used also
1976-1977 given the part number
Think my latest are from 1973-1974 period
« Last Edit: September 07, 2023, 03:43:41 AM by J_Speegle »
« Reply #9 on: September 07, 2023, 06:59:19 PM »
I looked thru my TSB's and all I have on my shelf is 1968 to 1971 right now.
There was possibly and article on this repair in Mustang Monthly around February of 2005 if someone has access to those issues to look at.
Marcus Anghel
« Reply #10 on: September 07, 2023, 07:10:04 PM »
What is TSB?
San Jose built
11/69
Ps A/c
« Reply #11 on: September 07, 2023, 07:37:13 PM »
What is TSB?
Technical Service Bulletin(s)
These were regular communications between the production plants and the dealers/service managers related to issues, changes and problems experienced on different Ford models, engines or plants. Often they would include how to fix or address a problem. If a recall/campaign was issues those would also be covered in a separate dingle document. Sometimes the "fix"  posted in a TSB would include the hours Ford would reimburse the dealer for addressing the problem or fix
If you type in TSB in the search a number of them will turn up. Man/some with a scan of the original TSB
Here are a few examples of TSBs from other years
https://www.concoursmustang.com/forum/index.php?topic=28019.msg171156#msg171156
https://www.concoursmustang.com/forum/index.php?topic=12974.msg79160#msg79160
« Last Edit: September 07, 2023, 07:41:04 PM by J_Speegle »
