Author Topic: 68 SJ Trunk Wiring harness retainer tab protector tips  (Read 1825 times)
Offline bullitt68
« on: October 26, 2023, 11:58:24 PM »
Just curious about these wiring harness retainer tab protector tips. There were none on my car, but the assembly manual indicates that there should be 11 for the trunk. Were they also used on other wiring tabs in the car or just the trunk?
Mike
Re: 68 SJ Trunk Wiring harness retainer tab protector tips
« Reply #1 on: October 27, 2023, 12:40:55 AM »
I have only seen those rubber tabs on 68's in the trunk. I don't know if they were on all but certainly a fair amount given how typical they are seen. I think NPD sells them if not they are relative easy to make.
Online ruppstang
« Reply #2 on: October 27, 2023, 12:41:30 AM »
Yes all 68s should have them. I do not know of any other place they were used.
Offline bullitt68
« Reply #3 on: October 27, 2023, 01:14:41 AM »
Thanks Bob I ordered a set from NPD
Mike
Offline bullitt68
« Reply #4 on: October 27, 2023, 01:15:14 AM »
I did not see them anywhere else in the Assembly Manual
Mike
Offline dkknab
« Reply #5 on: October 27, 2023, 08:51:14 AM »
I didn't count if I have all 11 but here are two pictures of three of them in my 68.
David Knab
289 2V, AT, PS
Nugget Gold Interior
Offline bullitt68
« Reply #6 on: October 27, 2023, 03:07:35 PM »
Thanks great photo reference. Is that all original?
Mike
Offline dkknab
« Reply #7 on: October 27, 2023, 07:28:55 PM »
I'm the third owner of the car so I'd like to think it is. The second owner only owned the car for a very short time.  He owned a Ford dealership where I purchased the car.
David Knab
289 2V, AT, PS
Offline bullitt68
« Reply #8 on: October 27, 2023, 07:59:40 PM »
Are there more photos of your car?
Mike
Offline dkknab
« Reply #9 on: October 27, 2023, 09:46:30 PM »
Yes,  I've included many under Member Restorations titled My 1968 NJ Sprint B Pictures.
If there is anything specific I can assist with,  please don't hesitate to ask. I won't claim to have all the info but am trying to get there.
David Knab
289 2V, AT, PS
Offline bullitt68
« Reply #10 on: October 27, 2023, 09:49:04 PM »
Great thanks David I will check it out
Mike
Offline dkknab
« Reply #11 on: November 02, 2023, 05:05:45 PM »
Well I counted my tab protectors and I have nine. I am missing the two under the driver side rear fender. I double check the Electrical Assembly manual page and it does say 11 are required so I am assuming those two tabs should have them.
Bob, can you explain how you would make these please? No sense in buying 11 since I only need 2. Thank you.
David Knab
289 2V, AT, PS
Offline 67350#1242
« Reply #12 on: November 02, 2023, 09:01:48 PM »
Looks like you may be able to use heat shrinkable tubing to make your own.
67 Coupe SJ 11/16/66
67 GT350 SJ 2/01/67
« Reply #13 on: November 02, 2023, 09:29:49 PM »
Yes maybe but it will not look like original. The open on both ends heat shrink tubing will be open on the normally closed end of the factory tab cover. A liquid rubber type product like what you dip tool handles in would make for better results. It is not worth the trouble IMO given the nominal price NPD sells them for.
Offline bullitt68
« Reply #14 on: November 02, 2023, 09:43:44 PM »
Agreed Bob. Plastidip would work, but is better suites for parts off the car that you can actually dip the part in as intended. For my money I would just order a set, like I did. Only $11.47 for 11. Hard to beat a buck a piece imo and free shipping to boot!
Mike
