Author Topic: Looking for a little help with a leaky brake line  (Read 650 times)
Offline DaveF
« on: June 04, 2025, 11:45:48 PM »
I just got done installing my complete brake system on my 70 Mustang. All of the flare fittings sealed up perfectly the first time as did all of my flexible lines?except one. It seems that the right flexible lines that goes to the brake piston is leaking. It?s not very much, but if I leave it alone for a couple of hours, I can see a couple of drops of fluid on the floor. Both crush washers are in place and the bolt is definitely tight. I tried breaking it loose and retightening the bolt. That helped some, but didn?t take care of the problem. I was wondering if anyone on here might have a tip, or suggestions. Thanks
1970 Mustang Mach One
428 SCJ w/Drag Pak 3.91
Metuchen plant
Built 9/5/1969
Offline 6t9m1
Re: Looking for a little help with a leaky brake line
« Reply #1 on: June 05, 2025, 07:17:45 AM »
Have you tried hitting the head of the bolt then retightening it as this may help to seat the copper washers.
May69 Mach1 SanJose 351toploader
« Reply #2 on: June 05, 2025, 08:38:06 AM »
Also check to be sure the bleeder screw is fully seated.
Offline DaveF
« Reply #3 on: June 05, 2025, 12:09:49 PM »
I?m not sure that I understand. You suggest hitting it? On the top of the bolt head?
Metuchen plant
Built 9/5/1969
Offline OldGuy
« Reply #4 on: June 05, 2025, 08:36:15 PM »
I would suggest getting 2 new gaskets and annealing them prior to installation. You can anneal the gaskets by placing them on a flat steel surface (like a piece of sheet metal or any flat, fairly smooth steel surface) and heating them with a propane torch. This process will provide a softer gasket which deforms more easily.
Offline DaveF
« Reply #5 on: June 05, 2025, 09:16:54 PM »
Annealing the washers is a good idea. I?m not sure, but I may have found the problem. It seems that the bolt may have been bottoming out before the gaskets were sealed. I took about 0.050? off of the end of the bolt and it seems to be working so far. I put a Kleenex under the bolt. I guess I?ll find out tomorrow whether I got it or not.
Metuchen plant
Built 9/5/1969
