Author Topic: WTB the little bracket that holds the flasher....  (Read 4432 times)
Offline MWM
« on: April 18, 2013, 06:17:28 PM »
For a '65 mustang.
Thanks!
Offline Twilight65
  • Gold Level Subscriber
Re: WTB the little bracket that holds the flasher....
« Reply #1 on: April 18, 2013, 08:04:39 PM »
« Last Edit: April 18, 2013, 08:08:07 PM by Twilight65 »
Offline MWM
« Reply #2 on: April 19, 2013, 12:49:01 PM »
I'm actually looking for the metal cage the holds the blinker flasher. I think thus was also used at the emergency flasher too?
Thanks!
Offline Twilight65
« Reply #4 on: April 19, 2013, 04:14:19 PM »
The 65 and 66 Electrical Assembly manuals call out for a twist-in tab mounted flasher (no bracket, plastic tab part of flasher) to the LH air duct. I have one of this type in my junk box. My Oct 65 build has a bracket and screw so there must have been a running change. It may be the same as the emergency flasher bracket, C1TF-13351-A or C5SZ-13351-A. The 65 emergency flasher bracket was part of the switch assembly.
Offline MWM
« Reply #5 on: April 19, 2013, 05:24:59 PM »
Could you post a photo please?
Thanks!
« Reply #6 on: April 19, 2013, 06:19:47 PM »
Picture worth 1000 words. You can see the tabs on the flasher to the right. It is a Tung-Sol 224, it is rated for "2 lamps". The other one is a Littlefuse 552 536 and may be the emergency flasher type (will handle 6 bulbs). The bracket "may" be the one you are looking for. It will work on horizontal or vertical inserted flashers. There is another style that Ford used that is a straight in (vertical) mount. The one mounted on the LH duct (aka vent) on my 66 is between the duct and the firewall. I needed a mirror to see it, no way to get a camera in there.
Offline MWM
« Reply #7 on: April 19, 2013, 06:34:15 PM »
Jw66k,
The blue flasher on the right is what I have! Would you consider working something out on the bracket as I would like to add to my restoration in progress. Also, thank you for the descriptions and photos. This helps me understand the differences!
« Reply #8 on: April 20, 2013, 12:20:55 AM »
Sorry, the bracket is spoken for.
Offline rockhouse66
« Reply #9 on: April 20, 2013, 08:30:25 AM »
I searched many junk cars to find the little flasher clip for the emergency flasher on the passenger side, as shown on the assembly manual.  When I went to install it on my air conditioned car, there was no space to put it as shown in the manual  >:(  Would be nice to learn how this was handled by Ford on an A/C car?
'66 GT FB
Offline Andrew@MagMustangs
    • MagMustangs
Offline MWM
« Reply #11 on: April 23, 2013, 04:34:30 PM »
Thank you Mag for the help on the listing.
Rock, did you get a response? I too have an A/C car.
Thank you!
Offline rockhouse66
« Reply #12 on: April 23, 2013, 05:38:15 PM »
Thank you!
No, I didn't.  The clip in the eBay listing looks like the one I found but it won't fit where the assembly manual shows it located.  Interferes with the A/C.
'66 GT FB
Offline C5ZZ
« Reply #13 on: April 23, 2013, 11:26:16 PM »
Is this the bracket you are looking for?
If so I have one, leave me a pm if interested.
MCA # 00945
Rangoon Red/Red Interior
Offline MWM
« Reply #14 on: April 27, 2013, 02:35:40 PM »
Thanks to everyone for your help, I now have both brackets!
