Author Topic: Tilt steering for a 69  (Read 2402 times)
Offline Rsanter
« on: February 27, 2014, 12:35:26 PM »
I have a chance to buy a complete tilt setup from a 68 . I have always heard that the 68 and the 69 tilt steering collumns were the same/ interchangable. Is that true?
If there is a difference between them what is it?
And how much is the system worth now days anyway?
Bob
Bob
66 mustang GT conv 289 AT deluxe int - high school car
66 mustang conv 289 -3x2v-4spd deluxe int
68 mustang conv basket case
69 mustang conv 302 AT
66 mustang coupe hotrod/racecar
Re: Tilt steering for a 69
« Reply #1 on: February 27, 2014, 08:25:03 PM »
Not true. Close, but not the same.
Offline Rsanter
« Reply #2 on: February 27, 2014, 11:35:00 PM »
How close and what would it take to conver it?
I did go ahead and buy it or there was someone right behind me to grab it....anyone want to trade?
Bob
Bob
Offline dieseldave
« Reply #3 on: February 28, 2014, 12:17:35 AM »
Hope you got the rag joint and lower steering shaft, they are different between tilt and non tilt. As I remember the '68 and '69 use different tilt-a-way wiring and vaccum valve. The vaccum valve bracket is different so you may have to make a bracket up. Wiring may have to be modified. I would look at at '68 and '69 tilt wiring diagram and see if the wiring will work. You will also need a vaccum storage cannister that mounts in the right wheel well. A tilt-a-way  vaccum diagram may also help. There is addition info in the 1969 factory service manual. Tilt-a-way is a great option.. Good luck.
Offline Rsanter
« Reply #4 on: February 28, 2014, 02:54:17 AM »
I got the rag joint, the vac can and the wiring.
Looking at the replacement parts it shows the turn signal harness as being the same for the 68 and 69 but I believe the connector is different.
Bob
Bob
« Reply #5 on: February 28, 2014, 09:05:16 AM »
I think I may have the vacuum release bracket but need a picture to verify it is a 69.
« Reply #6 on: February 28, 2014, 06:13:52 PM »
This help ?? ;)
Offline Rsanter
« Reply #7 on: February 28, 2014, 11:02:13 PM »
J
What did you want for that part
Bob
« Reply #8 on: March 01, 2014, 04:55:35 AM »
J
Not for sale - was used on a project a few years back. Just snapped some pictures so I would have them for times like this - when others are asking to see examples
« Reply #9 on: March 01, 2014, 12:01:11 PM »
Yes that is the one I have. Thanks Jeff. All I have is the bracket. Rsanter if you are interested PM me.
