Author Topic: Emissions Decal - 69 NJ 428CJ  (Read 9780 times)
Offline Brian Conway
« on: May 02, 2014, 11:23:16 PM »
     Does a early 69, 428 Mach 1, 9T02R, get an emissions decal in the engine compartment ?  If so; should it be the C8OE-9C485-C version and where is it applied ?  Thanks,  Brian
« Last Edit: May 03, 2014, 01:40:12 PM by J_Speegle »
5RO9A GT  4 Spd Built 5/29/65
9TO2R SCJ 4 Spd Built 9/19/68
Owner Driver Mechanic
San Diego, Ca.
Offline jimhib
Re: Emissions Decal
« Reply #1 on: May 03, 2014, 01:47:14 AM »
  My Nov. 68 car has the original on the drivers side valve cover just below the plug wire loom.
Offline jimhib
Re: Emissions Decal
« Reply #2 on: May 03, 2014, 01:48:57 AM »
   I'm not home now but thinking about it, the decal on the valve cover has the ignition info. If that's the wrong sticker then the other one is on the firewall more towards the passenger side.
Re: Emissions Decal
« Reply #3 on: May 03, 2014, 04:31:56 AM »
So a chrome valve cover car ..
The emission/timing striker goes on the drivers side valve cover as mentioned above.  It was applied at the engine plant so where the car was built doesn't come into play in answering this question. But thanks for including it anyway ;)  Same location fro a 390 also
Only the service decal goes on the  drivers side  shock tower
You didn't include when your car was built and it appears there are a few different trends (with the service decal) depending on the time period )
Of course many owners have copied other cars from other plants and builds - see them all the time on the internet and at shows :(
Couple of pictures to help illustrate
Re: Emissions Decal
« Reply #4 on: May 03, 2014, 09:37:14 AM »
quote jimhib
      Thank you Jim.  The valve cover decal is the one I would like to know the part number from.  Yes: That decal has the rpm idle settings.  What info does your decal have; decal number and rpm settings ?  Brian
San Diego, Ca.
Re: Emissions Decal
« Reply #5 on: May 03, 2014, 09:46:18 AM »
[quote J_Speegle
Yes; OE chrome valve covers.  Would the valve covers also have a date stamp ?
Service decal was not part of my question but is vertical on the left shock tower.
The build date for my car is located in my signature.
The oil filler cap in the pictures has a plastic elbow.  Is that OE correct or should it be the metal elbow ?     Thanks,  Brian
San Diego, Ca.
Offline jimhib
Re: Emissions Decal
« Reply #6 on: May 03, 2014, 12:32:27 PM »
Brian:
    The original valve covers for my car have a date stamp just behind the filler cap on the drivers side. Not deep but visible. Mine also has no decal on the drivers side shock tower as I've seen on some cars. My build date was Nov 18, 1968. Also I'm the original owner.
Re: Emissions Decal
« Reply #7 on: May 03, 2014, 01:37:46 PM »
As mentioned above yes like most stamped steel parts. The plating like paint can make some a little difficult to read but on others its pretty easy.
The metal verses plastic elbow has been something tossed back and forth over the years. Looking at my collection of pictures the very early cars like your all have the metal elbow on them (9T102221, 9T102871, 9T119655)
« Last Edit: May 04, 2014, 01:59:49 AM by J_Speegle »
Offline rockhouse66
Re: Emissions Decal - 69 NJ 428CJ
« Reply #8 on: May 03, 2014, 04:38:09 PM »
There are two versions of this emission sticker for '69, early and late.  I don't recall the changeover date and am not home to look it up but my guess would be your car should have the early one.  I think the suffix letter changes at some point (as do the specs); for example, from -A to -B or -B to -C (don't recall which).
'66 GT FB
Re: Emissions Decal
« Reply #9 on: May 03, 2014, 06:23:02 PM »
quote jimhib
Brian:
     Thanks Jim.  The Marti/built date for my car is Sept. 19, 1968 .  A month earlier than yours and from the same plant.  Because you are the original owner and If you don't mind sharing;
1.  What is the date stamped on your chrome valve covers.
2.  Do you have a chrome oil filler cap ?
3.  Does the oil filler cap, if chrome, have a plastic or metal elbow?
Rockhouse is correct about the different emissions stickers.  The early sticker C8OE-9C485-C  shows idle settings; 650 for autos and 700 for manuals.
        The later sticker  C9OE-9C485-D  shows idle settings; 550 for autos and 700 for manuals
Thanks for all the Help.  Brian
San Diego, Ca.
Offline jimhib
« Reply #10 on: May 04, 2014, 12:55:58 AM »
Brian:
      I'm in Anchorage for the next few weeks but I'll have Mike look at my covers and let you know, possibly post a flick. My filler cap is Chrome, the elbow plastic, both came with the car.
Offline mjgraniero
« Reply #11 on: May 04, 2014, 03:20:37 PM »
Brian:
Here are some photos of Jim's valve covers. I'll post a few more as soon as these load
1969 Mustang Fastback (in restoration)
428CJ, Ram Air
C-6
9F02R
Offline mjgraniero
« Reply #12 on: May 04, 2014, 03:26:05 PM »
More photos...  If you need any more, let me know.
428CJ, Ram Air
C-6
9F02R
« Reply #13 on: May 04, 2014, 04:47:44 PM »
 author=jimhib
Brian:
      Thanks Jim.  Looks like; Nov. 1968 chrome and plastic.  Valve covers dated 10 3 D3 and ? 12 D2.  Emissions decal; 650 rpm for autos and 700 rpm for manuals and most likely the C8OE-9C485-C emissions decal.                                              Thank you Mike for the photos.  Brian
« Last Edit: May 04, 2014, 05:37:31 PM by Brian Conway »
San Diego, Ca.
« Reply #14 on: May 04, 2014, 07:43:57 PM »
Thanks for posting - do you happen to know the real build date of the car and or when the engine was assembled. That might help narrow down the plastic verses metal application. ;)
That's an odd place (looking at all the other examples)  for the service decal to be placed on a NJ car - thanks for sharing
