Author Topic: What radial size on 14x7 Steel Wheels  (Read 8815 times)
Offline fastfret7
« on: May 10, 2014, 05:18:47 PM »
What radial tire best matches the F-70 WSW Polyglas tire that came on the 1970 14x7 steel wheels?? I see some are saying 205/75/r14 and 215/70/r14
Again, thanks for everything!!!
Offline jimhib
Re: What radial size on 14x7 Steel Wheels
« Reply #1 on: May 10, 2014, 11:58:03 PM »
   I have 205's on the front and 235's on the rear, works quite well.
Offline Rsanter
« Reply #2 on: May 11, 2014, 02:48:50 AM »
I have 215 70 r14s on the 69 conv and they look right to me
Bob
Bob
68 mustang conv basket case
69 mustang conv 302 AT
Offline sah62
« Reply #3 on: May 11, 2014, 08:56:29 AM »
I'm going to disagree with everyone and say 225-70-R14. Just do the math - the best info I could find identified the diameter of an F70x14 tire as 26.2". The modern equivalent that comes closest to that size (26.402" diameter) is 225-70-R14.
The formula is diameter = ((2 * tire-width * aspect ratio) / 25.4 ) + wheel rim size. Plugging in 225-70-14 you get ((2 * 225 * .7) / 25.4 ) + 14 = 26.402. Other diameters for comparison:
205-70-R14: 25.299"
215-70-R14: 25.85"
« Last Edit: May 11, 2014, 03:51:22 PM by sah62 »
Scott Hollenbeck
2019 Lincoln MKZ 3.0T AWD
2003 Mercury Marauder 300A
(more non-Ford stuff)
Offline jimhib
« Reply #4 on: May 11, 2014, 11:50:57 AM »
Scott is basically very correct, I had done the same calculations when radials first became vogue. I used the setup I have because my car has no power steering, making a slightly narrower tire more appealing while diameter of the front tires is inconsequential. I wanted a bit more traction on the back so for daily driving and an occasional smack of the firewall I went with the 235's on the back with a speedo drive gear change. The car steers easier, and has a good bit more traction for daily driving and an occasional pounding of the gas pedal.
Offline 70cj428
« Reply #5 on: May 11, 2014, 03:09:22 PM »
Quote
So one really good burnout will make the back tires just about perfect..........        ;D
Offline mjgraniero
« Reply #6 on: May 11, 2014, 10:42:29 PM »
205-70-R14: 25.299"
215-70-R14: 25.85"
Scott,
The OP referenced 14x7 wheels for his 1970.  I believe the 1969 originals were 14x6. Will the 215-70-R14 work on a 14x6 wheel?  I ask because I'll be looking for tires for my '69 pretty soon.
« Last Edit: May 11, 2014, 10:44:06 PM by mjgraniero »
1969 Mustang Fastback (in restoration)
428CJ, Ram Air
C-6
9F02R
Offline sah62
« Reply #7 on: May 12, 2014, 08:57:26 AM »
Scott,
I don't know. What size was the original tire?
Scott Hollenbeck
Offline jimhib
« Reply #8 on: May 12, 2014, 11:14:09 AM »
Scott:  Mikes car was a typical Mach l and came with 14/6 rims covered with F70-14 no size white letter Goodyear Polyglas tires.
Offline sah62
« Reply #9 on: May 12, 2014, 12:11:15 PM »
Understood, I still don't know which of these tires will fit on a 14x6 wheel. I'm using 225-70-R14 radials on my 14x7 styled steel wheels and they fit just fine. Your local tire shop should be able to tell you if any of these will fit a narrower wheel.
Scott Hollenbeck
Offline jimhib
« Reply #10 on: May 12, 2014, 01:47:11 PM »
Scott: I thought all wheels other than the boss 9's & magnums with the F60-15 tires used six inch rims. Styled steels measure six inches on the beads but seven to the outside. A seven inch would have been a bit wide for an F70-14, but good for a 60 series. Maybe I've got my numbers screwed up, have to correct if so.
Offline sah62
« Reply #11 on: May 12, 2014, 09:35:16 PM »
The standard 1970 Mach 1 wheel was 14x7, as were the optional styled steel wheels. Other 1970 Mustangs used 14x5, 14x6, or 15x7 wheels depending on the specific application.
Scott Hollenbeck
Offline fastfret7
« Reply #12 on: May 13, 2014, 11:54:20 AM »
I cannot find any 225-70-R14 wsw... Does any know a specific tire I should be looking for??? Thanks
Offline Rsanter
« Reply #13 on: May 13, 2014, 12:46:52 PM »
I have the 68-69 GT wheels on my car and the 215s seem to fit very nice
Bob
Offline rayms69
« Reply #14 on: May 13, 2014, 01:29:55 PM »
I have Firestone supreme P215/70R-14s, needs bigger tires for sure, the car is way too powerful for these puny rims/tires. Sorry, the cars look better with more substantial rubber, even my 65 with a 5.0 destroy puny 14s. Safety is more important than anything.
10-26-1969 Dearborn 428 SCJ auto
