Author Topic: 70 mach firewall hole  (Read 9071 times)
Offline restomod
« on: June 02, 2014, 08:18:31 PM »
Ok 70 Mach 1 351c 4bl Metuchen plant and not an original AC car but has AC now. On the first pic posted with all the numbers there is no hole to the left of number 11 and above number 3 on that car. In the pic of the car with the red jack stands there is a hole there and another hole to the left of that with the rubber plug. Anyone know what either hole was for or which cars had those?
Secondly mine has the hole to the left of #11 but has this funny looking plug in it (the third picture).  I am beginning to think it is not original?  It has two holes in it that are open right through to under the dash.
1970 Mach 1 Grabber Orange 351c-4v
Re: 70 mach firewall hole
« Reply #1 on: June 02, 2014, 09:21:29 PM »
Any idea of when any of the three cars in the pictures were built?? No reason, for looking  IMHO, at early cars (for example) when you have a late car - Often these can be running changes not used through the whole production year
 So lets start with a solid foundation to work from ;) - I think your looking at examples with different options, applications and time periods from your car and this is creating some confusion
As far as the bottom picture with the rubber plug in the firewall hole - if we knew what options and accessories your car originally we might be able to figure it out with those to guide us
« Last Edit: June 02, 2014, 09:50:15 PM by J_Speegle »
Offline jmlay
« Reply #2 on: June 02, 2014, 10:53:03 PM »
There was recent discussion on the Boss302  & 428cj forums in regards to the hole to the left of "11" & above "3" being the location of the choke cable.:
http://www.428cobrajet.org/forum/index.php?topic=21246.msg142650#msg142650
http://www.boss302.com/smf/index.php?topic=65844.0
Mike
1969 Mach1 428 CJ Ram Air
San Jose
Scheduled Build: 1/2/1969
Actual Build: 1/3/1969
Released: 1/8/1969
Offline restomod
« Reply #3 on: June 02, 2014, 11:16:22 PM »
Thanks Jeff I know the details can be important I definetly have no idea of the details in the first two so they probably make things worse as far as information.  I was more or less happy to find something close enough to show people where on the firewall I was taking my picture for since it is hard to describe.
Mike thanks for the links will look at them in the morning.
I will also link up all the details from my marti report in the morning.  Its the only thing I have to go on for options and dates.
Lastly Jeff, saac 39 was bit farther away than the the Glen was (the glen 30 minutes from my house) but I really missed watching you guys judge the 66 Shelby's this year.  I hope there were some good cars this year.
« Reply #4 on: June 02, 2014, 11:22:12 PM »
As mentioned the second one appears to be from a Boss or CJ car so extra holes will just confuse you
Thanks that should help - as there appears to be a few differences between what holes are used or installed depending on these things
I handed off the 66's to John Brown and the rest of the team this year to focus on a Div 1 car and help out judging a few others with Mr Gaines :).   Guess I played clean -up position this year :)
Offline Brian Conway
« Reply #5 on: June 03, 2014, 01:07:58 AM »
     Just for a reference.  Brian
5RO9A GT  4 Spd Built 5/29/65
9TO2R SCJ 4 Spd Built 9/19/68
Owner Driver Mechanic
San Diego, Ca.
« Reply #6 on: June 03, 2014, 10:17:00 AM »
hole above #3 is screw hole for 69 throttle cable & 70 cable has square hole & no screw hole as cable just snaps in place.
Offline restomod
« Reply #7 on: June 03, 2014, 06:35:25 PM »
Thanks specialed but that's not the hole I mean that is to little and to low.
Mike that hole for the choke on those cars looks to small to be this one I have, not that someone couldn't have hogged it out.
Just for reference, right cars or not the hole I am trying to identify isn't even on the picture with all the numbers, and looks to be on the red jack stand picture (although I am not sure which one, the one with the grommet or the one without because I only have one). But this hole I have I believe is left of number 11 and above 23 on the flat part in the first picture.
My picture shows the rubber plug sticking out an inch or so with two smaller holes in it.
Jeff here is all the info from my Marti:
#152259
M code 351 4V
Metuchen
63c Mach 1
U code Grabber Orange
3A Black interior
9 3.25 standard axle
X FMX transmission (now a c6)
DSO 6913
Dealer Danville, VA
Order received 1/9/70
Serialized 1/13/70
Bucked 1/15/70
Scheduled Build 1/21/70
Actually Built 1/21/70
Released 1/21/70
Sold 1/28/70
Options:
Black hood stripe
rear deck spoiler
fmx
sport slats
power front disc brakes
power steering
argent styled wheels
« Reply #8 on: June 03, 2014, 09:30:32 PM »
Mid year, 351 4V, Auto, no AC, with PS, P/disc  and a non- Calif sent car.
Ok now we can get to work
The rubber plug you have appears to be a buckhead plug that seals and holds a pair of rubber vacuum lines that pass through the firewall at that location
like this example
On other cars it simply had a rubber plug installed
Believe this is part of /related to the Dist-O-Vac system installed on M code automatics
« Last Edit: June 03, 2014, 09:36:17 PM by J_Speegle »
« Reply #9 on: June 03, 2014, 09:45:10 PM »
From an upcoming (read need to get to it as well as others) Article for the Library (stopped at 69 so far) showing the system, those lines and the plug
Offline restomod
« Reply #10 on: June 03, 2014, 10:15:42 PM »
Thanks Jeff you are a genius that's what it has to be.  I assume it is empty because one of the following reasons, it is now a c6, has petronix, and a Holley 600 electric choke carb?  This all started because I was looking for a hole to run a wire to the coil for an aftermarket steering wheel tach.  Just so happened to find that nice little "buckhead" plug as you call it!  Then it made me nervous that it was too perfect and still open and not sealed.
Please do tell when the 70 library will be online!  I know my car is not a concours car nor do I want it to be (read I can't afford it) but I want to know why it is or isn't and be knowledgeable.  I cant seem to get near a a judged MCA event since I got the car (read even more 2 kids under 5 and car seats) so right now I am not assuming anything.  I have so many questions that would be answered somewhat easily by actually looking over a similar car that I have been holding off.
Anything based on the above marti information that is crazy unique for these metuchen cars mid year that I should look for?  The car has been restored and restored pretty well but I am still sorting out what was original and put back on versus aftermarket replacements.  One part at a time I will figure it out.
« Reply #11 on: June 03, 2014, 10:33:18 PM »
The second picture with the red jack stands, is this your car? Do you know anything about whose car it is?
Offline restomod
« Reply #12 on: June 03, 2014, 11:31:22 PM »
Sorry Scott I got both pics from the thread below on VMF.  The original poster of the pic says it is an original red 70 C/J but I dont think it was his car nor does he know where.  It is also where I posted the picture of my question thinking they might know.  I ended up bringing it here, I am going to put an update to this link now becasue no one knew over there.  Just so plant/year/engine/tranny specific and so much crazy info out there.
http://forums.vintage-mustang.com/vintage-mustang-forum/656949-70-mach-1-firewall-holes.html
Offline buening
« Reply #13 on: June 04, 2014, 01:50:06 PM »
That picture is from Sven's (SW Pruett on many forums) build detailed here: http://1970boss302.blogspot.com/2010/10/august-thru-september-2010.html
Excellent work Jeff. I've not messed with cars that have the Distovac, so this one had me stumped!
« Reply #14 on: June 04, 2014, 03:28:02 PM »
The reason that I was asking, that the photo could also have been a 1970 Cougar. I know the other posters were seeing the reinforced or wrap around shock towers and were thinking big block Mustang. All 1969/70 Cougars received the reinforced shock towers.
